    • Unanswered topics
    • Active topics
compatible plugins for progdvb x64
kaveh20
kaveh20
Fri Dec 18, 2015 7:13 am
#1 by kaveh20
Why any plugin (card sharing &...) didn't work on 64bit version of progdvb?
They execute on 32bit version very well.
please improve your 64bit version that acts with plugins like 32bit version
or compatible progdvb x64 with card sharing and other plugins
  • Fri Dec 18, 2015 7:56 am
Re: compatible plugins for progdvb x64
win64 application can load only x64 dlls. This is limit of OS...
But you can still use x32 version.
  • Fri Dec 18, 2015 8:17 am
Return to “Modules”
Re: ProgTV 3.8.3 - Trail Peri…
Do you have license? In any case - try install previous version of ProgTV. I'll test it again tomorrow
Prog, Sun Sep 07, 2025 3:15 am
ProgTV 3.8.3 - Trail Period E…
On my Windows 11 machines, I am now getting this message in a pop-up box - WinLicense Your trial period has expired
MG317, Sat Sep 06, 2025 4:51 pm
Re: IPTV channel list issues
1. I changed the leading character to * and it sorts properly now. It seems you are removing leading . characters from t
noremorse57, Sat Sep 06, 2025 2:08 pm
Re: first response feedback
Thanks for feedback. It is more convenient to respond to text as in a video. 1. I am not can repeat first problem with
Prog, Fri Sep 05, 2025 4:21 pm
  • It is currently Mon Sep 08, 2025 10:53 am
