Bugs in v4.83.2
Bugs list:
1. When 'TV Windowed' ProgDVB is minimized & recalled back from tray, all but channel list are dropped e.g.: toolbar, navbar, statusbar (infects recent versions)
2. ProgDVB v4.83.2 alters channel list files making them unreadable to just the previous version of 4.82.4. I considered to be a bug since channel list alteration isn't mentioned anywhere else.
3. Being unrepeatable but definitely a v4.83.2 bug, ProgDVB sometimes records unchosen alternate audio stream in MPEG2 although decoding the right audio. (It happened (2/11) times & Ive changed nothing but ProgDVB version for quite some time which eliminates other sources of error)
(sorry to post this way but bug feedback thread has some kind of PID talk going on...)
Not here...
2. Being unrepeatable but definitely a v4.83.2 bug, ProgDVB sometimes records unchosen alternate audio stream in MPEG2 although decoding the right audio.
Also not here
3. ProgDVB v4.83.2 alters channel list files making them unreadable to just the previous version of 4.82.4. I considered to be a bug since channel list alteration isn't mentioned anywhere else.
This is not a bug ...and discussed before -> viewtopic.php?t=951&start=0&postdays=0& ... highlight=
also here : viewtopic.php?p=2708#2708
4.83 Now possible use more one device over one module (for example two card of one manufacture of dual tuner card) .
As you see..changes are not a bug they are a part of a new feature...
Thanks for the channel list post...
But you couldn't say 'not here' as if it's not really there. At least please say 'not for me'. I've seen one other guy affected by the minimisation problem so it's there for some others like me afterall...
As for different audio stream, I was quite happy with 4.82.4. It happened for me with v4.83.2. I don't owe a lie to you, I just reported what happened. Something you can't replicate doesn't necessarily eliminates a problem which really happened. (I also am sure it was v4.83.2 because everything else (PC, OS, etc.) but it worked for me for quite some time)
But again thanks for your input...
thats the same in my eyes ...
depends on the card and/or used codecs
PC1 : Athlon 1400 at Asus A7A266,512 MB DDR,WinXP PRO SP2 + DX 9 c,GeForce FX 5200 mit 128 MB-TV-Out,3x80 GB HD,Hauppauge Nexus 2.1 (driver 2.17g),Hauppauge PVR 350
PC2 : P4,3.2 GHz,2 MB Cache,800 MHz FSB,2048 MB DDR-RAM,WinXP PRO SP2 + DX 9 c,320 GB HD,GeForce 6800 GT,500 GB ext. HD,Nova-T USB Stick,Skystar 2 (driver 4.40)+ Hauppauge DVB-C (driver 2.17g)
19.2° east
used software : Progdvb 4.83.2,4.79.x,4.56.2 and many others...with FFDSHow and AC3filter 1.11
no problems at all...with 4.83.2 except of some very old and small bugs (e.g. Timeshift slider etc...)
I totally withdraw my audio part of the list because I found;
ProgDVB NOW RECORDS MULTIPLE AUDIO PIDs in the stream within MPEG2 format. As far as you don't bring this to be a cause of problem I guess you're also unaware of this feature too.
This feature is something I've dreamed of many times but only exclusive to TS recording until now... I reported it as a bug because 2 or more of the programs I used with videos misused the PIDs with higher numbers (causing wrong language audio) whereas the original language resides in the lowest PID.
With setting correction on these programs recordings are better than ever with multiple PID recording. Sorry to bother about this and thanks for this feature.
p.s.: lost toolbars are still there... ;)
No , but this is possible only with the Elecard edition of progdvb....
I don´t have/use this version...because its not free...
But you can use the pid writer to record .ts (with MULTIPLE AUDIO PIDs)...but this is possible only with budget cards without mpeg-2 decoder...
