    • Unanswered topics
    • Active topics
AT40USB supported?
chris1984
chris1984
Thu Jan 14, 2016 8:04 am
AT40USB supported?
#1 by chris1984
Hello, I have this USB http://www.alitronika.com/at40usb.htm box. I have installed the drivers and I can watch the channels from the software included. Can I use progdvb with this device? Is there any special configuration needed ?
  • Thu Jan 14, 2016 8:09 am
Re: AT40USB supported?
Afaik - NO. I am not have any ASI devices and not test that.
  • Thu Jan 14, 2016 11:44 am
Return to “Hardware”
  • It is currently Sat Jun 14, 2025 12:00 am
