    • Unanswered topics
    • Active topics
Anysee E30S2 plus and diseqc1.0 (4ports) problem
slavusec
slavusec
Mon Apr 11, 2016 2:18 pm
#1 by slavusec
I have latest ProgDVB x86 on win8.1 x64. (BDA) BDA anysee digital tuner (DVB-S2) as hardware and Aditional API - anysee. Port1 is Astra 23.5E and work, port2 is Astra 19.2E dont work (L-90 Q-0).Original software from Anysee (anysee Satellite Viewer) work whit port1 and port2 correct.Cant you help me? Thanks!
  • Wed Apr 20, 2016 1:40 pm
Re: Anysee E30S2 plus and diseqc1.0 (4ports) problem
I am not have api for anysee :(
But try anysee.Device on place of BDA.device in TV SOurces.
  • Wed Apr 20, 2016 2:28 pm
slavusec
slavusec
#3 by slavusec
http://www.megafileupload.com/6ylb/Desktop.zip
Images from my settings
Desktop.zip
(104.28 KiB) Downloaded 555 times
  • Wed Apr 20, 2016 2:55 pm
slavusec
slavusec
#4 by slavusec
No other help
  • Sat Apr 23, 2016 12:49 pm
#5 by Prog
I am not have any documentation from anysee. But please try Microsoft mode also.
  • Sun Apr 24, 2016 5:47 am
slavusec
slavusec
#6 by slavusec
Dont work
  • Tue Apr 26, 2016 12:10 pm
Return to “Hardware”
Re: ProgTV 3.8.3 - Trail Peri…
Do you have license? In any case - try install previous version of ProgTV. I'll test it again tomorrow
Prog, Sun Sep 07, 2025 3:15 am
ProgTV 3.8.3 - Trail Period E…
On my Windows 11 machines, I am now getting this message in a pop-up box - WinLicense Your trial period has expired
MG317, Sat Sep 06, 2025 4:51 pm
Re: IPTV channel list issues
1. I changed the leading character to * and it sorts properly now. It seems you are removing leading . characters from t
noremorse57, Sat Sep 06, 2025 2:08 pm
Re: first response feedback
Thanks for feedback. It is more convenient to respond to text as in a video. 1. I am not can repeat first problem with
Prog, Fri Sep 05, 2025 4:21 pm
  • It is currently Mon Sep 08, 2025 11:01 am
