    • Unanswered topics
    • Active topics
windows 10 netframe work
jalendran
jalendran
Fri Jan 27, 2012 1:09 pm
#1 by jalendran
In windows 10 which netframework is supported?
If I install netframework 2 or 4, it was blocked by windows and showing that already it was installed
What I do?
thank u
  • Thu Jun 23, 2016 10:22 am
Re: windows 10 netframe work
ProgDVB request installation of 2.0. What message you have?
  • Thu Jun 23, 2016 12:02 pm
Thex
Thex
Mon Dec 30, 2013 3:16 pm
Re: Windows 10 .NET 4.6 Framework
#3 by Thex
If you start ProgDVB:
http://go.microsoft.com/fwlink/?linkid=296822
Why not update <supportedRuntime> :?:
  • Sun Jun 26, 2016 2:12 pm
Thex
Thex
#4 by Thex
Still same error in 7.16.
Displays error message that prompts user to install the correct version*
Support .NET Framework 4 or 4.5
But with right setting it will work even on 4.0!
  • Fri Sep 02, 2016 5:48 am
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 10:13 am
