PROGDVB CLIENT & PROGTV ANDROID
LINUS
LINUS
Sat Oct 04, 2008 11:43 am
#1 by LINUS
Hi guys,
I cant setup correctly progdvb and progtv on my smartphone.
I would like to stream channels from pc to my smartphone. I get server error on my smartphone.
Can someone post a little tutorial for both setup?
I will very appreciate it. Thanks.
Linus
  • Sun Jun 26, 2016 5:31 pm
Re: PROGDVB CLIENT & PROGTV ANDROID
Do you have list from server on smartphone? Check firewall on PC.
  • Mon Jun 27, 2016 3:57 am
LINUS
LINUS
#3 by LINUS
Thanks for reply.
I dont have list on the phone. but connection failure from server.
I have disable firewall on Windows and on router.
Antivirus is disable too.
There are somebody that are using these app. without problems?
Ciao linus
  • Mon Jun 27, 2016 1:39 pm
#4 by Prog
Check IP of server in client settings and network setting on server.
  • Mon Jun 27, 2016 3:34 pm
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 6:15 am
