Import settings from ProgDVB
zozi
zozi
Mon Aug 22, 2016 3:13 pm
#1 by zozi
Hi,
I'm trying import settings in android app ProgTV but i can´t figure out how do export settings, channels etc from ProgDVB Windows.
How i can do that?
Thanks in advance
  • Mon Aug 22, 2016 3:16 pm
Re: Import settings from ProgDVB
You can simple copy data folder of ProgDVB.
  • Mon Aug 22, 2016 3:23 pm
zozi
zozi
#3 by zozi
I tried copy the files i show in imagem attached but in Android give me importing error.
I coppy the files from appdata/progdvb
Is something i do wrong?
Thanks
  • Mon Aug 22, 2016 5:32 pm
#4 by Prog
Sorry for delay. Please try this version
http://www.progdvb.com/progtva_download.html
  • Wed Aug 24, 2016 4:31 am
#5 by Prog
Please use 2.22.1 ProgTV Android and last ProgDVB (>=7.15.3e) with special dialog in ProgDVB.
  • Fri Aug 26, 2016 4:22 am
zozi
zozi
#6 by zozi
Hi,
thanks for your solutions, it works great :)
when you will do something like progDVB client ou server for linux? ubuntu or something... :D
chears
  • Fri Aug 26, 2016 12:30 pm
#7 by Prog
Not great now because request too many steps from user...
ps: I am not have time to other versions of ProgDVB.
  • Fri Aug 26, 2016 12:39 pm
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 4:00 am
