hi everybody
I scaned iptv
yesterday
#EXTINF:-1, SCTV4 test4
http://112.197.10.212:80/session/67c30b ... index.m3u8
today
http://112.197.10.212:80/session/a5b599 ... index.m3u8
next time of today
 http://112.197.10.212:80/session/a5b599 ... 1469424740
but it change flowtime, i don't enough time scan it
Please tell me, How do auto san it, if don't have tool scan them, please send to me addon service play it on Kodi
thank you
																																							Re: Scan iptv Token
#2Looks like protection from scanner
But do you have way for playback that in kodi? What way?
Re: Scan iptv Token
#4yes. This is main reason of token. It must be generated new by software or server on every channel access.
							Re: Scan iptv Token
#5Can you tell me,how do to server it? and can you buil a software do it?
please, help me.
thank you
							please, help me.
thank you
Re: Scan iptv Token
#6here service for Kodi
https://raw.githubusercontent.com/lnt90 ... -1.0.0.zip
here list iptv add in LIVE TV on Kodi
http://pastebin.com/raw.php?i=UGNLXiWF
and here service get link on web
https://drive.google.com/file/d/0B_kGyU ... VsY0k/view
add list iptv on kodi
http://bit.ly/iptvhtvonline
Re: Scan iptv Token
#7i recommend you read up and give a try to LiveStreamPro video-addon created by Shani for kodi. use XML file and Regex and python function to generate Token and other stuff ... you can find this kodi addon at Fusion (tvaddons.ag).
Regards
add this to filemanager "
http://fusion.tvaddons.ag/
then go to install from zip     (go to xbmc-repos >  international   >    and install pakistani-repository.shani-2.8.zip)
their forum:
http://forums.tvaddons.ag/
also give try to my addon :-p :
https://forums.tvaddons.ag/addon-releases/46359-persia-video-addon-iranian-live-tv.html
Windows: 7 Service pack 1 , 32bit   _-_   DVB: Sky Star 2.8a PCI   _-_   CPU: 2.6 GHZ Dual core X2 AMD   _-_   RAM: installed 4Gig , 2.75 Gig usable  _-_  Graphic: ATI Radeon x1200 series total available memory : 1663
							Re: Scan iptv Token
#8thank you
I'm not a developer, sorry can you tell me to clearly, i must edit what file, please?
here link i need add (important)
http://27.67.50.6:18080/155.m3u8?Adapti ... IMESHIFT=0
and here website (if you can tell me )
https://fptplay.net/livetv/vtv1-hd
Please teach me add it
thank you.
P/s: if you edited, please attact only file edited.
thank you.
Re: Scan iptv Token
#9Do you mean link on channel? You can simple enter it to search line of ProgDVB.
							Re: Scan iptv Token
#10This is one link for example. The link of chanel swich flow to time
http://112.197.10.212/session/[b]67c30b ... a8421e4c65[/b]/di3wnp/sctv_hd_giai_tri_tong_hop/1500000/index.m3u8
It change flow to time
http://112.197.10.212/session/[b]a5b599 ... a8421e4c65[/b]/di3wnp/sctv_hd_giai_tri_tong_hop/1500000/index.m3u8
The now,i need a service auto paste new link when old link lose of chanel on Kodi or a app play chanel anytime
The Progtv just scan one time when it search. The link is lose when a new day.
Re: Scan iptv Token
#12Please what? Your links have protection of using (token). You must look provider and сonditions of channels using.
