progdvb android timeout error - loop
simo
simo
Thu Sep 08, 2016 7:27 am
#1 by simo
Hi, do you know if is possibile to loop video streaming player?
Now, if the stream goes "Error! Timeout." i need to push "Try again" to restart stream...can the app do it automatically like "loop" button in vlc?
thanks
S.
  • Thu Sep 08, 2016 7:35 am
Re: progdvb android timeout error - loop
It is last version? I fix this problem 1-2 versions ago.
  • Thu Sep 08, 2016 8:55 am
simo
simo
#3 by simo
Thank you for reply.
I use 2.22.6 on android tv box
  • Thu Sep 08, 2016 11:47 am
#4 by Prog
Try wait 30 seconds. And send me logs if still problem.
  • Thu Sep 08, 2016 2:26 pm
simo
simo
#5 by simo
i try to wait 30 seconds but change nothing.
if i press "Try again" it restart correctly.
please find attached logs
thank you so!
Simo
Logs.zip
all log
(118.64 KiB) Downloaded 539 times
  • Fri Sep 09, 2016 4:48 pm
#6 by Prog
Are you sure about "timeout" error? In logs ConnectionFailed.
  • Sat Sep 10, 2016 4:37 pm
simo
simo
#7 by simo
This is the error show when i lost ETH connection...do you think is possibile to push try again automatically?
  • Sun Sep 11, 2016 7:06 am
#8 by Prog
ProgTV/ProgDVB must automatic update every 5 seconds. I check this problem in near days give you test version.
  • Sun Sep 11, 2016 7:27 am
simo
simo
#9 by simo
Thank you so much!
Best regards
  • Sun Sep 11, 2016 8:40 am
#10 by Prog
Try new beta http://www.progdvb.com/progtva_download.html
  • Wed Sep 14, 2016 2:43 pm
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 3:59 am
