Hi.. I'm using a provider list with Progdvb and progtv android. i've set up progdvb for pc with categories, epgs en logos and in my pc all is ok.
all the logos have the sames names of channels. i've copied my settings in my smartphone and tv box android ( the progdvb_data folder and ChLogos folder ). after importing my settings and set up the logos folder in android, i've launched the android app. the channels it's ok with categories and epgs, but the logos not appears in standard mode or Icons mode.
there is any option to view the channels logos in android ?
thanks in advance and sorry for my english
P.S. i've tested the last official version and the last beta version
Re: channels logos
#3Is perfectly set to the ChLogos path in my sdcard of smartphone or tvbox android and confirmed with ok. ( in my case /storage/sdcard1/ChLogos )Prog wrote:Check options->Channel list->Logo path
Re: channels logos
#5No any problems with logo. Set path to folder with logos in Options->Channel list
Re: channels logos
#6Hi... I've understand the problem.
I've created folders in my list. Tha list have 400 channels + 1.000 on demand and i've created folders ( in ProgDVB for Windows ) like, MUSIC, SPORT, CINEMA, ENTERTAINMENT, etc etc... This folders help me to have an easy serach of channels for genre.
I've copied and imported the progdvb_data in my tablet to have the same folders created win Windows Version.
With this structure ( with folders ) there's no logo.
If i put the m3u list full, without modifications the 80-90 % of logos appears beacause all the logos have the same name of channels. I i import the list changed for me with folders for genre, there's no logos..
Sorry for my english and thanks in advance..
Re: channels logos
#8no.. only links.. all the logos are in local storage, pc, micro sd, nothing in remote..Prog wrote:Hm. No logos in m3u?
the m3u list only contain the links TS or MKV with live and On Demand contents separated for type
---- MUSIC -----
all Music Channels
---- SPORT -----
all Sport Channels
but is a big list of hundred of links..
There's no problems. If is not possible have logos with my personales folders, i will survive without logos
Re: channels logos
#10my m3u list is on a server and autoupgrade because the provider add new channels and new On Demand contents.Prog wrote:Do you create m3u in ProgDVB or at self?
In the sources of ProgDVB i put the remote address of my personal list. I can also save my playlist in a m3u file and import this if i want but in this case i lost the benefits of autoupdate on channels.
P.S. The strange thing is that only 2 channels have logos if i import my sctructure with folders and only in one of my smartphones ( i have also othe smartphone, a tablet and android tv box ) , if i not separate in folders 80-90% of channels have logos because i've renamed all logos with the same name..
if you want and need, i can make screenshots. I repeat that not is a real problem have channels without logos, is better but not very important. If i can help you to solve this problem for improvement of android app i'm here to test any thing
Re: channels logos
#12For Logos there's no problem but the m3u is personal and have a personal key and for privacy i can't send you in email ( is also secured on mi Italian IP ) . Understand me ..Prog wrote:Can you send me logos in archive and m3u on my email?
Re: channels logos
#14sorry for delay, my list structure is this.. ( is only an example )Prog wrote:You can clean all urls from this m3u.
#EXTM3U
#EXTINF:-1,- - - LIVE CHANNELS - - -
http://providername/live/account/number1.ts
#EXTINF:-1,CHANNEL 1 HD
http://providername/live/account/number2.ts
#EXTINF:-1,CHANNEL 2 HD
http://providername/live/account/number3.ts
#EXTINF:-1,CHANNEL 3 HD
http://providername/live/account/number4.ts
#EXTINF:-1,- - - - - ONDEMAND FILM - - - - -
http://providername/movie/account/namemovie.mkv
#EXTINF:-1,MOVIE 1
http://providername/movie/account/namemovie1.mkv
#EXTINF:-1,MOVIE 2
http://providername/movie/account/namemovie2.mkv
#EXTINF:-1,MOVIE 3
i'm not interested to have ondemand logos , i'm interested to have logos on live channels
the name of logo files are the same of channels
etc etc
if i charge my remote list without folders structure, the 80-90% of logos appears.
if i import a progdvbdata file created on my pc with a folder structure created for me ( SPORT,ENTERTAINMENT,CARTOON, ETC ) in my smartphones there's no logos, in my tv box appears only a little parte of logos ( 10% )
Re: channels logos
#15Hi i am new in forum.I need help.I want to add logos and EGP in m3u list IPTV and i dont know how...can you help me?
