Hi prog
thanks for continuously update of progdvb
1*could you please fix The channel list in ProgDVB Client
this problem found in all versions after ProgDVB 7.14.6
where the channels name or url keep changing!!
2*could you please add epg category( news,sport,movie..) and epg rating (+12,+16...) to XMLTV
where there are found in epg in server side but missing in IPTV client side
I downloaded last version and i hoped channel list and xmltv fixed but sadly it's the same
Thanks
Re: progdvb client channel list and XMLTV
#21. What problem?
2. Do you have categories in EPG dialog of ProgDVB?
#31-
channel list problem explained in that topic (post no 90)
viewtopic.php?p=72654#p72654
also in that topic
viewtopic.php?t=10308
2-
the attached pic is EPG from server side
there is category (comedy) and rating (+12) marked by red line
in client side (iptv client) they are missing for all channels
thanks
also in that topic
2-
thanks
#4Yes, current version not convert addition fields to xmltv. I can add this but not now because very busy in other part of app.
#5Thanks for your concern, I hope you do this in the future
what about progdvb client channel list problem?
#7Still not. I think you single user for this ask
btw, what tags you like?
#10epg category( news,sport,movie..) and epg rating (+12,+16...)
thanks
#11channel list problem SEEMS TO BE FIXED IN THE LAST RELEASE OF PROGDVB
problem reported in 10-9-2018, fixed in 10-12-2021, pretty long time but thanks any way....
however there are big problem with progdvb client, you totally forget about xmltv!!
scan progdvb client give channel list only without EPG!!
could you please fix that?
can you please add the additional tags to xmltv
epg category (news, sport, movie, comedy, romance...) and EPG rating (+12,+16...)
thanks
thanks
#12xmltv must working. Please send me logs of client updating.
#13that is the log at client side..
epg have zero event!
- Logs.rar
- (20.39 KiB) Downloaded 211 times
#14Imported 439 channels and 90 with guide.
1. How many channels with guide on server side? (from current list)
2. How many on client in result?
#15server side have 93 channels with guide, total event 20611
client side have 98 channels with guide, total event 0 (i tried update EBG database in client side!!)
