If I hit either Audio or Video Codecs page in Options, it shows just a blank page and progdvb freezes and has to be killed. This uses to work until recently.
Also, all sound lags video now by a few seconds - very annoying.
Re: Freezes when I try to amend codecs
#2Looks like protection function of one of codec. Please send me logs of ProgDVB
#7attached
another clue is the sound is almost always out of sync with the video and every so often is makes a stuttering or buzzing sound
- logs.zip
- (12.93 KiB) Downloaded 313 times
#9I changed it to prog and it syncs ok for a short while then burps then is out of sync. Still cannot open the codecs page
#10Select Prog audio renderer also. But is it Codecs crash in logs?
#11I sent you the logs. Perhaps you can tell me why I cannot load the codecs page?
#12I am not have in logs place of crash. Try look in WIndows logs (Event Viewer) name of codec which crash.
#13For example on my PC problem with Cyberlink when I am debuging ProgDVB.
#14I do not have problems with any other video software. I want to fix the out of sync audio and random stuttering and want to look at the codecs but cannot as the app just freezes.
#15noremorse it does that to me two and other issues, the problem is the codecs are not at par of android system player and codecs
,also i think VLC on PC is much better for IPTV,i think the more updates has been done the worse it gets,i real like the interface but the player
and codecs are lousy so far,so for IPTV i advise VLC on PC, i'm very sorry to say this cause i've been advising Prog DVB, but it let me down on IPTV.
