    • Unanswered topics
    • Active topics
Hi prog Dvb, Eternaltv iptv sevice with Xcodes
ivtec
ivtec
Fri Nov 24, 2017 7:32 pm
#1 by ivtec
Hi; i'm trying to set up Eternaltv with Xcodes but it gives an error. i know Eternaltv iptv won't let me use m3u file ,Doesn't Progdvb work only with Xcodes>? i have 2 other services that wok fine.
  • Mon Jan 10, 2022 6:26 pm
Re: Hi prog Dvb, Eternaltv iptv sevice with Xcodes
Must working.
Can you give test account on same server?
  • Mon Jan 10, 2022 6:40 pm
ivtec
ivtec
#3 by ivtec
Sorry I can't give you my Log in info, It use to work but Eternal tv stopped giving m3u lines ,so assume it won't work on prog dvb ?
  • Mon Jan 10, 2022 6:47 pm
#4 by Prog
Xcodes also good api for ProgDVB. I am not can say more without logs or test account
  • Mon Jan 10, 2022 6:56 pm
Re: IPTV channel list issues
1. Not clear. What char is problem? 2. I thinking about that. Many users ask me about new channels in end of list. But y
Prog, Tue Sep 09, 2025 8:50 am
Re: ProgTV 3.8.3 - Trail Peri…
Try install 3.8.4 version. And check data in registration dialog.
Prog, Tue Sep 09, 2025 5:51 am
I uninstalled and reverted to version 3.8.0 to resolve the issue. Yes, I have a license. I bought the license in 2020.
MG317, Mon Sep 08, 2025 12:48 pm
Do you have license? In any case - try install previous version of ProgTV. I'll test it again tomorrow
Prog, Sun Sep 07, 2025 3:15 am
  • It is currently Tue Sep 09, 2025 9:55 am
