Hi,
I have updated to ProgDVB7.52.4 and channels don't load. I get black screen and the message Waiting too long... no signal.
I downgraded to 7.51.9 and it works fine.
Re: Waiting too long... no signal
#2Please send me logs. You can install both versions to different folder for using and for test.
#3It's not always giving no signal. Sometimes it works like 50% maybe.
I have attached the logs when it crashed.
- ProgLogs.zip
- (143.07 KiB) Downloaded 1270 times
#4DIGI Sport 1 HD? Total no signal and traffic. But is it working in old version? Please check Settings->[device name]->mode. You can try other mode, for example "Microsoft"
ps: You can install old version to other folder for test.
#5Could it be that this is a problem with the satellite dish, a strong wind moved it, for example?
#6I am on cable. No problem with the signal. Old version works ok and is faster.
#7I get no signal on all channels. If I restart 3-4 times, sometimes it starts working ok. Device mode never changed, that's not the problem.
#9And what about ProgDVB 7.52.0, 7.52.1, 7.52.2, 7.52.3? ProgDVB 7.51.9 is very old. It dates 26.08.2023.
My opinion is that the first bad version may be ProgDVB 7.52.1 from 08.09.2023, though I am not sure. May be ProgDVB 7.52.0 (or 7.52.0a, b, c).
I have all this versions and can give them for testing.
#10I'm still using 7.51.06 for the problems with 7.52.X as you can see here: https://forum2.progdvb.com/viewtopic.php?t=13708kostan wrote: ↑Sun Oct 01, 2023 2:34 pmAnd what about ProgDVB 7.52.0, 7.52.1, 7.52.2, 7.52.3? ProgDVB 7.51.9 is very old. It dates 26.08.2023.
#11Oh, then it means that ProgDVB 7.52.0 also has problems. I have heard you.
