ProgDVB 4.89.7 (and 4.89.6) Failure...
Today i've got surprice...after the electrisity failed down... I open ProgDVB (both two) and it just don't start, (Program Not Responce, <windows vista>) and then i've got this error:
Here is the ProgDVB.INI (both of my 2 ProgDVB).
http://rapidshare.com/files/96421137/pr ... i.rar.html
After I Delete the <progdvb.ini> the Program Works OK (of course i set up my settings again)
my stuff:
1st PC: Core2Quad (2.5Ghz), ASUS Proximus Extreme (1007), 2GB ram, nvidia 9600GT*2 (PCIe) + 7950GX2,
< 1stDVB - TechnoTrend S2300 + C.I. /Driver Technotrend 219h>
and < 2ndDVB - TechnoTrend S2300 /Driver Technotrend 219h>.
WinVista32 Ultimate. ProgDVB 5.x
2nd PC: AMD 4600+ X2 (2.51Ghz), GIGABYTE GA-K8NSC-939 ( F8 ), 3GB ram, nvidia FX5950ultra (AGP).
< 1stDVB - Hauppauge NEXUS-s/Driver Technotrend 219h>
and < 2ndDVB - Hauppauge NEXUS-s + C.I. /Driver Technotrend 219h>.
WinXP 32PRO. ProgDVB 5.x
3st PC: AMD 4200+ X2 (2.2Ghz), Asus A8n32-SLI Deluxe, 3GB Ram, Nvidia 9600gt 512mb (PCI-E),
<1stDVB - Hauppauge NEXUS-s /Driver Technotrend 219h>
and <2ndDVB - TechnoTrend S2300 + C.I. /Driver TechnoTrend 2.19h>.
WinVista 32 Ultimate, ProgDVB 5.x
LNB (13E,19E,39E,16E,42E,30W,1W,5E,26E,28E)
Prog wrote:If you use BDA driver then must restart PC after crash any DVB software.
Yes i know that, and Thank you. But no, it's not crash by BDA driver, couse after i Delete the progdvb.ini (without restart) the progdvb works fine, i Think it is the latest line at my progdvb.ini,
Here is the only change betweine <Working .INI> and <crash .INI>.
Crash Progdvb.ini wrote:[MainTVWindow]
LastWindowMode=0
ShowToolBar=1
ShowStatusBar=1
ShowChannelListPanel=1
ShowNavigatorBar=1
TreePanelWith=456
WindowStatus=2C0000000000000001000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A04000007000000FB050000C203000007
StayOnTop=0
CurrentTree=0
[ChannelFilter]
Enabled=0
Min_Quality=0
Min_Level=0
Min_Sym=0
Other=1
EmptyNode=1
Radio=1
TV=1
Scrambled=1
Working progdvb.ini wrote:[MainTVWindow]
TreePanelWith=451
WindowStatus=2C00000000000000010000000083FFFF0083FFFFFFFFFFFFFFFFFFFF390300000600000015050000B203000038
ShowStatusBar=1
ShowNavigatorBar=1
ShowToolBar=1
StayOnTop=0
CurrentTree=0
LastWindowMode=0
But my quastion is, How does this change happend after electrisity Powerdown my Computer?
my stuff:
Prog, never mind - it doesn't matter, it's ok now
Thank you 8)
my stuff:
ProgDVB.ini is active all the time, as long as ProgDVB is running. Normally it would get updated and then closed on ProgDVB shut down. Else, merely impossible to predict...
As you can never foresee exactly, what Windows itself does on power failure, it's possible, some other important component - like e.g. the registry - may also get corrupted (partly). As we know, in such a case, Windows may try to restore something without asking, on next start. This may, for example, bring outdated DirectShow registry settings or alike.
Don't break your head on this...
Just make a backup copy of ProgDVB (at least), once it's working fine again. Then it's your decision, to go back at any time.
And make sure to also have valid backups for the system.
Prog wrote:Last version of ProgDVB backup last good config and restory after crash.
xmm the bavkup file is the <ProgDVB.ini_copy> or there is some more file? Couse last days I geting the same error over and over...
I just delete the <ProgDVB.ini_copy> and "rebuild" my Progdvb.ini from the beginning. I hope that it gona work...
my stuff:
Today i have the same problem...Progdvb HangUp at the Start and i've got the same error. I Delete Progdvb.ini and progdvb.ini_copy and all work OK...but tomorrow i will have the same problem :cry: :cry:
my stuff:
