at ()
at ..()
at ProgDvbNet.MainForm.(Object , FormClosedEventArgs )
at System.Windows.Forms.Form.OnFormClosed(FormClosedEventArgs e)
at IPDev.Skins.SkinForm.OnFormClosed(FormClosedEventArgs e)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at IPDev.Skins.Docking.DockForm.WndProc(Message& m)
at IPDev.Skins.SkinForm.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
ProgDvbNet
Assembly Version: 6.6.1.0
Win32 Version: 6.06.1
CodeBase: file:///C:/Programmi/ProgDVB/ProgDvbNet.exe
EngineApiWrapper
Assembly Version: 1.2.9.0
Win32 Version:
CodeBase: file:///C:/Programmi/ProgDVB/EngineApiWrapper.DLL
msvcm80
Assembly Version: 8.0.50727.1433
Win32 Version: 8.00.50727.1433
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.2.0
Win32 Version: 1.0.2.0
CodeBase: file:///C:/Programmi/ProgDVB/ProgDvbNet.bc.DLL
IPDev.Skins
Assembly Version: 1.3.11.0
Win32 Version: 1.3.11.0
CodeBase: file:///C:/Programmi/ProgDVB/IPDev.Skins.DLL
ProgDvbNet.EPG
Assembly Version: 1.0.5.0
Win32 Version: 1.0.5.0
CodeBase: file:///C:/Programmi/ProgDVB/ProgDvbNet.EPG.DLL
ProgDvbNet.CC
Assembly Version: 1.0.4.0
Win32 Version: 1.0.4.0
CodeBase: file:///C:/Programmi/ProgDVB/ProgDvbNet.CC.DLL
ProgDvbNet.Win
Assembly Version: 1.0.0.0
Win32 Version:
CodeBase: file:///C:/Programmi/ProgDVB/ProgDvbNet.Win.DLL
Accessibility
System.Design
System.Xml
System.Drawing.Design
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
And another two error:
Istruzione a "0x582d4f12" ha fatto riferimento alla memoria a "0x00000000". la memoria doveva essere "read"
Fare click OK per terminare l' applicazione.
Istruzione a "0x09499406" ha fatto riferimento alla memoria a "0x096c53e8". la memoria doveva essere "read"
And I repeat: With release 6.04.0x it' s ok.
Uhm... HERE LINK Problems with Pinnacle cards?
