TwinHan 1027 PCI Card cant startup with ProgDVB 4.81
1 post
jcha129
jcha129
Thu Jan 11, 2007 10:18 pm
#1 by jcha129
Hi
I just bought a TwinHan 1027 PCI Card, i install the the latest drive from the manufacturer's web site. http://www.twinhan.com. I try to start the WDM Twinhan device in ProgDVB, but i get error on start up the ProgDVB, Is this becuase ProgDVB dont support this PCI Card, It was on the market from Sep 2006?
I installed the latest version of ProgDVB4.81 on my widnows XP machine
  • Thu Jan 11, 2007 10:29 pm
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 2:40 pm
