ProgDVB can't lock transponder (Level: 90% Quality: 0%)
Hello,
Sometimes (very often) ProgDVB can't lock transponder (Level: 90% Quality: 0%) when i swith channels. ( tested on hotbird 13e: 11034, 10719, 11317). And in this time many other tranponders work fine. I can switch channels there and quality 60-80%
This problem exists on any TV channels (free and not free). Also I found two methods how to enable these channels
1. i can open settings -> options, press "Apply" , channel will be refreshed and "quality: 60-80%" appears, and channel will work.
2. i can close prodvb and open it again, and channel will be there with correct "quality 80%".
satttlite card: skystar usb hd
Is anyone knows how to solve this problem with progdvb, and make channels working without open/close proddvb every time when i want to swtich channel ? or may be here is skystar card problem ?
Thanks,
p.s. progdvb 6.24, 6.72
Re: ProgDVB can't lock transponder (Level: 90% Quality: 0%)
no diseq devices, just a skystar tuner and "lnb gl-201" converter,
"channel list -> channel search -> 13e horbird" or "channel properties -> update" doesn't help, and progdvb reinstall too,
Another example: channel 1 enabled, progvdb switched to channel2 and switched back to channel1 and sometimes channel1 doesn't work but sometimes works. No ideas why this happens, but close/open progvb always helps to enable "bad" channel1
Thats an old unsolved problem, that got worst (for me) with the Crazycat module. Disabling module makes quality show more easily.
Clicking to select the same channel a second time after a while, most of the times recovers quality. But many times only changing to another frequency bring quality back.
Seems theres something in the rotine of changing channels that de-tunes or looses frequency. The problem is more common with high quality signals.
