50% signal problem
Hi guys, I just bought a new laptop and installed progdvb. I have a dvb-t dongle ( bda driver) which works perfectly on my computer. When I finished istalling progdvb and launched auto scan for dvb-t channels all the frequencies had 50% signal even if the antenna is not even pluged-in and no channel was found. Any idea ?
Re: 50% signal problem
Prog wrote:DVB driver... May be USB driver.
I disintalled and installed again..updated to the latest version of .NET, still not working. it is certainly a driver problem because the dongle doesn't get warm ....i have win8.1, any idea? :( :( :( :( :(
Prog wrote:warm? May be usb power too low? Try connect over USB hub with self power unit.
I mean when the dongle works correctly it gets really hot, but in this case it gets just a little bit warm..usb ports are the same for pc and laptop
Prog wrote:but try USB hub with power. Analog signal very depended from power...
I just tried now and nothing changes :( :( it still doesnt work... it shows 50% signal in all the frequencies
